| | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 39 Apprentice | | Apprentice Joined: Oct 2009 Posts: 39 |  I'm having trouble finding stock looking tail/blinker lights for our 51 3100.Are these type of lamps available?Or do we have to put in a separate fixture? Our system is 12volt.Thanks for your help  | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | interesting looking truck. what is the horizontal bar down the side? Tail lights can be had from Jim Carter, see the links page. | | | | | Joined: Oct 2009 Posts: 39 Apprentice | | Apprentice Joined: Oct 2009 Posts: 39 | I've contacted LMC Trucks,their lamp assembly kit cannot also function as directionals is what they told me.I also ask JC the same question,waiting for a response. To Mater:the "horizontal bar"is part of the PO's paint job,a stripe,as soon as it warms up that paint is history!!They also did that to the grille. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I ordered the rectangular lights from page 66 of the 47-55 catalog. They are wired for turns on my truck. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have a dual filament socket then it can be used for both. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Jim Carter's lights are two bulb (equal to two filiment one bulb) | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The socket holder in the repop tail lamps is just a small aluminum extrusion which can either be modified to hold a dual filament socket or make a new one out of scrap tin.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
