| | | Forums66 Topics128,128 Posts1,056,668 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I recently noticed my GEN light staying on all the time when my truck was running. I reasoned it would be a good time to just replace the alternator with an internally regulated one. I followed the instruction in the FAQ section of here http://67-72chevytrucks.com/vboard/showthread.php?t=345919 I have 14 volts at the battery when the truck is idling, but the light stays on. I reversed the wires just to be sure...light stays on, but 12 volts at battery. I'm guessing I had the wiring part right. What will cause the GEN light to stay on? This is on a 250 six in a 66 C10 with warning lights rather than gauges. | | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I should also mention I just replaced the instrument cluster harness. So, the wiring is new from there to light. I'm guessing all this means a short between the gen light and the alternator. In this case, between the harness plug and alternator. Is there an easy method for finding it, or would it just be simplest to run a new wire? | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Does the light go out when you unplug the 2-pin connector at the back of the alternator? If not, you've got an unwanted ground between the light and the alternator. One leg of the 2-conductor circuit to the idiot light should be hot with the ignition on, and the other should ground through the alternator anytime charging current is not flowing. It sounds like you're getting your ground somewhere before the signal gets to the alternator. Jerry
| | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Ok, that makes sense. Between a couple of boards and advice, i think I am actually starting to understand this circuit. I will try unplugging the connector at the gen to see what happens. | | |
