7 members (Hanks custodian, 2-Ton, TUTS 59, Otto Skorzeny, festerhairball, HandyAndy, dt235sd), 83 guests, and 2 robots.
Topics128,060
Posts1,055,836
Members48,427
#59343 04/18/2006 3:06 AM
Junior Member
Junior Member
1954 235 wanted to put on new vacuum advance.Order one from chevy duty and it came it was not the same.Mine was at a 45degree or so and this one was staight.It would have been alright if I would have got the clamp to but they do not carry it.Can any one help me with this?
Jim Geurts
#59344 04/18/2006 1:42 PM
Jim,
Here is a photo of the 216/235 /261 truck vacuum-advance without the clamp. I think the advance mechanism that is at a different angle is for an automobile 235. Jim Carter has the truck vacuum advance new and used.
Tim
#59345 04/18/2006 8:32 PM
Junior Member
Junior Member
tclederman, If there is no clamp, how does it turn distributor without sliping
Jim Geurts
#59346 04/18/2006 8:48 PM
Yes, you need a clamp. I guess that Jim Carter (and, maybe Chevy Duty, also) expects that you will use the old clamp.
#59347 04/25/2006 1:17 AM
Junior Member
Junior Member
Well i ordered the one for my truck but they must have put one on from a car so its not the same.Does anyone know where I can get the clamp that will fit the truck vacuum advance.
Jim Geurts
