6 members (TexasJim50, Cletus1950, Gdads51, Leo, fonz8261, 78buckshot), 70 guests, and 3 robots.
Topics128,179
Posts1,057,068
Members48,460
#59338 04/18/2006 2:30 AM
Junior Member
Junior Member
Hello to all. I want to swap out the 4 speed floor shift to an automatic. Probably a th350 or 400--depending on which I find first. The truck is a 70 3/4 ton 4 wheel drive. I looked in previous forums and couldn't find any info --although i'm sure there's plenty somewhere. My question--can anyone tell me what all I need to do to get this done. What linkage I need?--new steering column? (I was going to put in a tilt style anyway) Will any year tranny work? What problems I may run into? Any help would be greatly appreciated. Thanks Matt
Your truck originally should have a 208 transfer case.Go to a company I belive the correct name is Trans Dapt .They have conversions for pretty much any thing .I'm in the process of a 4 spd to 700R4 and I want to use the 208 transfer.I belive all you change is the output of the trans to adapt to the transfer.Keep us posted and sorry I dont have a link to the site .
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
Junior Member
Junior Member
It's a 205 transfer case. I checked out the web site (trans Dapt)no help--they have adaptor plates only--Doesn't answer above questions. Thanks anyway. Anyone else? M
Junior Member
Junior Member
I can't believe nobody has done this swap. Where is everybody?
I gave you the wrong company sorry about that I had a couple cold ones when I made the reply.Try Advanced Adapters they will have what you need.
