10 members (5 Window 9434, Hush, Southerntruck, hapydirty, klhansen, 78buckshot, Otto Skorzeny, D B Cooper, Peggy M, Hawkman),
105
Mod | | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Hey guys,
Ok, back in the summer, I attained a set of ralley wheels for my truck from its previous owner, but they were a bit rusty. So I sandblasted them down to bare metal, and repainted them. I went with a cheapie approach with the painting, because I plan to have them painted the same colour as the truck when I get the truck repainted. What I did after sandblasting, was prime them with two coats of spray can primer, then I put 3 coats of spray can paint on them, which was apparently meant for wheels (so said the label) and then after that, 2 coats of spray clearcoat. They were fine until the snow came. The truck sat outside in the snow, and wasn't driven until the snow melted. Well, the part of the wheels that had snow sitting in them has already rusted. What did I do wrong? And what kind of paint, or painting technique should I go with next so this doesnt happen again? Such a waste of time, that was...aaarrggh | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the problem with wheels is the joints, hard to really get in there with the sandblasting or the paint .... also rattle can paint isn't the best, need electrolytic derusting as a start then epoxy primer
Bill | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | How is electrolytic derusting done? | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Search the forum or web for electrolysis. Here | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | and after you get you rims cleaned use a foam or model brush to get primer & paint deep into that crack between the center & outter part of the rim or it will rust there also...Joe | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | Where you went wrong, is the cheapy route. Rattle can paint will not hold up to the elements regardless of all the prep work you do.
The sand blasting would have removed all the rust, your prep and paint was the problem.
Frank Cox Cox Custom Cars
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | |
