2 members (Erniegp, J Lucas), 89 guests, and 2 robots.
Topics128,054
Posts1,055,781
#592646 11/15/2009 8:43 AM
Which type of spot weld cutters do you like? Self pointed or the drill bit type?
Is Blair still really a good one?
Which brand do you like?
Broke my old one today so need a couple new ones.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don G. #592664 11/15/2009 2:14 PM
I prefer the Hougen "RotaCut" cutters kit number 11075C and order an extra couple of the smallest two cutters.
I've cut hundreds and hundreds if not thousands of spotwelds with them. I would resharpen them on the belt sander occasionally. They only die when you catch one tooth to many times and break it off, but can still last a while longer missing one.
Looks like they have a size or two even smaller than the kit comes with, I may order a couple of those for the little bitty spot welds.
I've used the Blair ones, but they don't seem to last as long.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #592690 11/15/2009 4:27 PM
We've been using Wivco Spot-Eze spot weld cutter for about three years (100+ cuts). The bits have had to be replaced a few times but the cutter is still sharp.
Tim
http://www.toolsource.com/spot-weld-drill-p-105368.html
https://www.autobodytoolmart.com/2856-wivco-spot-eze-pro-p-11596.aspx
RJ Offline
i use the NAPA Brand #770-3841 it had the double sided blades when you wear out one side you just flip it over, and you can get the replacement blades there too.
I use Wurth 8 mm spot weld cutters. http://wurthindustry.thomasnet.com/item/drill-bits-2/spot-weld-drill-bits/pn-10853?&seo=110
I first saw them used in Germany and brought some along, but they are available in the US. After using them, I don't want to use anything else.
Thanks guys I will check these out. I used to get them when we did rework at work but since retired miss the perks. LOL!
62Blue
Don
62Blue
62Chevy in progress
Moderated by  MNSmith
