| | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I was digging around in one of my step Dads barns today, he is into early Chevy cars and has a couple in the barn. I was looking at what I think is an early power steering set up. Looks like it all it is is one end of a hydraulic ram connected to about the middle of the tie rod and the other end connected to the frame. I can fabricate the parts to attach the ram to the tie rod and the axle.
What I would like to know from you guys that know more then me and that have more experience in this area is what is/are your opions of this set up and how good does it work. I will be putting this on a 38 GMC. I don't like armstrong steering
1938 Gmc 1/2 ton
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It is a relatively easy option, but not one people use very often, I'm guessing either parts are expensive or the newer PS gear boxes work better even if it is more work to install.
Grigg | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I have never used this system or driven anything that has, but it is not too uncommon. The basic idea is that the pitman arm or drag link has a brain. That is to say it senses the pushing or pulling of the drag link to control the power assist ram. I believe some people have complained about bump stear with this setup, but that was likely due to poor steering geometry.
There are many options available to improve the steering of your 38. One of the most simple solutions is to swap out the steering box and colum with one from a 41-46 chevy or gmc. This is virtually a bolt in change and will give you a more modern "Saginaw" recirculator ball bearing steering gear. This upgrade will reduce steering effort by up to 30%. Proper size tires will also help with the ease of which your rig will turn.
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I don't know what was used in passenger cars, but that is the basic setup used in trucks till GM switched to the power steering box. It was also used in the Vette up till at least 77.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think it started in cars in the mid 50's as an option. They ran the PS pump off the back side of the generator in those models.
Grigg | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Used on chevy cars through 64, vettes way on up to near the 80's, and on several 4wd trucks later than that. You have exactly the right idea to anchor one end of the ram to the axle and the other to the tie rod---guaranteed no bump steer. The hoses from the sensor in the draglink to the ram will get a good work out mounted this way but no more than brake line hoses. They are a good working set up with the main draw back being hoses that can hang low and catch on things if used on a low vehicle. I guess vettes weren't used much for off road so it wasn't a factor with them.
Evan
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Don, steering with an orbitrol on industrial equipment is different than hydraulic assist on a vehicle.
| | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | well I got to work taking it apart and now I understand what is going on with it. I know I could make it work but I just flat out do not want to spend all the time and money making it work, so my search for a power steering gear box that will work continues.
FYI some times even after some of you guys have explained stuff I still have to get my hands on what ever it is to understand what your talking about
Thanks for all the useful info you gave and I got
1938 Gmc 1/2 ton
| | | | | Joined: Oct 2009 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 136 | After you've worked on something you can see a picture of it in your head, If you've not taken it apart and put it back together, sometimes the picture is blurred.  | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't beleive there is a kit for your '38, but a similar approach to the kits made for '47 to '54 trucks might work. I paid $40 at a u-pull-it for the right power steering box to make that work.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | Old Dollar you are so right about that.
OldSub that's my step dad thought he had an original for the kit your talking about for the 47-54. I plan on going to the local pick and pull and just start looking and measuring to see what I can find.
1938 Gmc 1/2 ton
