2 members (Uncles51, Shardean),
50
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Does a 54 Chevy 235 have an oil pump or a dipper? Virg | | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | I believe all 235's had oil pumps. the 216's had the dippers. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | All 216s, 235s, and 261s had oil pumps.
dyslexia strikes again - Thanks waldo53 for the correction (below)
Tim
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I think tc meant to say "all 216s, 235s and 261s had oil pumps". The "low pressure" 216s and 235s had dippers for the rods but the crank bearings and rocker arms were fed via a pump. | | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | I thought all 216's were dippers and 235 and others had a pump. How do you know if it is a low pressure one? Virg | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | All 216's and all the early 235s are dipper-oiled on the rod bearings, but pressure oiled on the mains and rockers and they all have an oil pump. '54 (actually '53 Powerglide) was the first of the "high-pressure" engines that also lubed the rod bearings with oil from the pump. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | How do you know if it is a low pressure one? The simple way is to look for the triangular-shaped "oil distributor" assembly down near the oil pan rail on the driver's side middle of the engine. It's a piece of stamped sheet metal attached with three bolts, IIRC. The splash-oilers will have that item, whether they're 216 or 235, and the full-pressure 235's don't have it. Jerry
