5 members (rfs56trk, Gib70, Lightholder's Dad, Gray_Ghost, 1 invisible), 134 guests, and 1 robot.
Topics128,080
Posts1,056,060
Members48,433
LHG
Offline
Hi guys, thanks to you all my 53 chev p/u is ready for paint. One thing bugging me.
Starts great cold. Drive for 20 minutes, park and then cranks real slow.
Battery tests good. rebuilt generator and matched regulator. Have not touched the starter.
Thank you all.
Joe/LHG
Joe,
- 216/235 engine?
- 6v or 12v?
If 6v:
- weak starter (works OK when cold but gets weaker when warm)
- wrong battery cables for 6v - use 0 (1/0) or 00 (2/0) gauge cables (12v cables are usually 6 gauge)
Tim
LHG
Offline
Thanks Tim,
I have the right cables.
It is a 235 cu inch , 6 volt.
When it does not start, if I check the battery, the cells are all up and good.
Thanks again. Joe
Ex Hall Monitor
Ex Hall Monitor
Check your ignition timming
