| | | Forums66 Topics128,042 Posts1,055,597 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 46 | I have an hei distributor for a 250 ci engine to install in my 235, I keep seeing distributor modification but haven't found the modification they're talking about. Could someone explain this. | | | | | Joined: Feb 2004 Posts: 29,761 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,761 | The flange where the distributor housing rests on the block is just a little too far down on the housing for the oil pump drive to engage properly. I machine it off, and fabricate a collar that's adjustable so the engagement of the drive gear and the pump drive can be adjusted properly. Mine also incorporates a squared-off spot with a bolt hole in it to use the original hold-down bolt to secure the dizzy to the block. Jerry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's explained in the techtipsBill | | | | | Joined: Mar 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 46 | | | |
