4 members (Donf, msmall, 2 invisible), 120 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
My '46 came without either of these strips. I called Chev's of the 40's and they don't sell reproductions. They DO for '47's but advised me they can't be adapted to work on the '41-'46 cabs.
I am wondering if anyone has spare ones they want to sell (hopefully cheaply, ha, ha)? But more likely, could I make some out of ordinary sheet metal stock? I don't even know what these strips look like, width, length? Do they have any lines, details of any kind I need to hold the windlace?
On the same subject, are there some kind of strips across the bottom of the doors/cab floor to hold that weather stripping?, if so I don't have that either. I did a search on this but came up with nothing. Any help/advice appreciated. Dan
NOBODY, has pictures of these metal pieces?
Detail
It would be very difficult to make those parts (for me at least) as they have one edge beaded and the other bent 45 degrees. In addition, the ends of the curved pieces are are stamped so the long pieces can fit over. Much easier to find used ones. And, again, the bottom windlace is retained by the rocker panels.
Check E-bay, I see them on there all the time.
kingisomer, I can't thank you enough for those pictures. They're a huge help. Now that I can see them I can check to see what I've got/what I'm missing? I THINK I have the curved pieces installed but aren't those stepped reliefs on the ends (for lack of a better description) supposed to be for the long piece to overlap it? I'm assuming the long pieces are the verticals for the front & back of each door? They meet each other over the center of the door opening, is that about right? Do you have a picture of these pieces installed? You've been REAL help to me. Thanks again, Dan
P.S. Going to eBay now.
Dan, I sent you a PM,
Dale
HUGE props to 46Canopy for hooking me up with a source for these windlace retainer strips. Can't thank you enough, Dan
For those that may come later in search of info, after double checking my cab, there is NO metal retainer strip along the bottom of the cab doorway except the metal transition piece from the flat floor to the rocker of the cab. It is held in by clutch head screws and that piece in turn holds the weather strip that runs across the bootom of the doorway. There is a short approx 3/4" wide flat strip that holds the windlace on the "front" of the doorway - the part where the kick panel goes. And there is another similar flat strip that goes along the latch side of the doorway. Then there is a somewhat similar piece that goes over the top of the door way that interfaces with the long vertical piece I just spoke of and finally there is a more involved part that covers each A pillar adjacent to the windshield. Hope this helps. As soon as I get everyithng straightened and primered I'll post pictures to this thread. Thanks again to everyone that helped, Dan
Moderated by  ndkid275, Phak1
