2 members (tesa, Ponchogl),
50
0
Mod | | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 7 New Guy | | New Guy Joined: Sep 2005 Posts: 7 | Hi guys, thanks to you all my 53 chev p/u is ready for paint. One thing bugging me. Starts great cold. Drive for 20 minutes, park and then cranks real slow. Battery tests good. rebuilt generator and matched regulator. Have not touched the starter. Thank you all. Joe/LHG | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Joe,
- 216/235 engine? - 6v or 12v?
If 6v: - weak starter (works OK when cold but gets weaker when warm) - wrong battery cables for 6v - use 0 (1/0) or 00 (2/0) gauge cables (12v cables are usually 6 gauge)
Tim
| | | | | Joined: Sep 2005 Posts: 7 New Guy | | New Guy Joined: Sep 2005 Posts: 7 | Thanks Tim, I have the right cables. It is a 235 cu inch , 6 volt.
When it does not start, if I check the battery, the cells are all up and good.
Thanks again. Joe
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Nov 2000 Posts: 171 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 171 | Check your ignition timming | | |
