2 members (Cosmo, Wayne67vert),
43
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | I'm restoring the distributor but am having difficulty placing it back in. I don't think I'm putting the end of the shaft down into the oil pump slot. I'm wondering if the end of the shaft is to big. When i turn over the engine by hand, the shaft and rotor spin. Did a PO put in the wrong one or am i not trying hard enough? The Delco Remy model # is 1112403 | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have the dist set down in the right position slowly rurn the engine with a light pressure on the dist. When the dist shaft lines up with the oil pump it will drop in rest of the way. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | I did what you suggested and it seems to seat properly now. The point set is 2 1/8" long. Am i right in thinking this may have been from a gmc? Will that matter at all and will it affect setting the gap? Thanks | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Master parts book shows that dist. was for '55-'57 Chev all 6 cyl 12 volts. Is that the dist. that was in there when you got the truck?
I do believe the '54 drive gear on the cam is steel but the '55-'57 dizzys used a cast iron gear and you can't mix and match them.
Hopefully someone with more detailed info will chime in soon but I wouldn't run the engine too long until you know for sure. | | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | That's the dist that came with the truck. The last time it ran was at least 10 years before i got it. The '54 235 is originally from a car. Would i be able to put a '54 dist gear on my current dist? | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The short answer is yes. I think you could use any gear from '47 thru '54 and it would work (216 or 235). If your '54 engine is from a powerglide car or a Corvette, you won't need to do anything, these used cast iron cams. Just look at the stamped numbers just to the left of the distributor, if they end with 54Y or 54YG you're good to go. Otherwise, the gear change should work. Hopefully someone who has done this will chime in soon. | | | | | Joined: Sep 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 59 | If you want to upgrade to HEI , Tom Langdon makes one for the 54 235. Easy to install and worth the time/ money. I never believed my Grandpa when he said points were horrible until I was on the side of the road checking the gap and re-gapping it almost everyday until I changed to the HEI. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Properly set up points should last a minimum of 10,000 miles, unless you do something dumb like leave the ignition switch on with the engine stopped and the points closed. The reason for going to HEI in the mid-70's was to meet the federal requirement that emission-related components (including ignition systems) had to go 50,000 miles service-free. Jerry
