0 members (), 149 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
#591927 11/12/2009 6:52 PM
I have been in the search for a 4.56 or higher rear gear. I was reacenly offered by Bill a rear from his K20 parts truck. He is sure the front was a Dana and the rear is a 4.56 Posi Detroit. My question is 2 things, is or will it fit a HO72 and secondly will it fit my DRW axle.
Thanks Everyone for your help to this new young bolter!
Chevrolet 1957 3800 dually flat bed.
If it's an Eaton with the drop out center section, yes it will fit your housing.
Steve
'49 3800
'52 3600
'57 3100
What year K20? If it's a '72 or older, it'll work. If it's '73 or newer, it will not, as they used the Corp 14 bolt. Unless you're looking to swap the entire differential, then you could use it.
Bill Burmeister
