3 members (klhansen, dt235sd, 1 invisible),
67
0
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Hello, Its dark, and I need good back-up lights for my 1-ton flat-bed. My truck is still 6 volts, but I might be able to power 12 volt lights.. I am thinking of lights that would mount below my bed, and or at the top of my head-ache rack. I want lights that look "period", like they belong on my old truck. Any recomendations? What are you using? Yhanks, Chris | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You could probably get away with using utility lights for a tractor. Any good farm store like TSC, Rural King, Farm & Fleet, or Big R should have them. They'll be in the automotive electrical areas. Might be able to find 6 volt versions if they have a tractor resto parts dept.. I would mount them below the bed, to get the light where it'll do the most good.
Bill Burmeister | | |
