7 members (Hotrod Lincoln, 46 Texaco, tclederman, papas52, dt235sd, MNSmith, 55shaker),
133
0
Mod | | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 22 New Guy | | New Guy Joined: Jul 2003 Posts: 22 | One has 340 gears, another 390's and the other a LSD. One has 11"X1-1/2" brakes and I haven't lugged the complete one out yet that has the LSD. Can I install the LSD with any of the gear sets? How about the late brakes? All look interchangable but the later axel is much wider than the other two that are around 56" backing to backing plates. One has an integral stud on the pumpkin for a panard bar. I guess that the axels are from 50's-60's pickups thanks
Greasy Thumbs
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There's several different 12 bolts, more info is needed to tell if what you have can be swapped around. 12 bolt Passenger and truck do not interchange, and there are at least 2 different carriers within each version for the different gear ratios. It will depend on what gear the LSD is set up for as the what can be run on it. The Truck 12 bolt ran from '63 to about '76 (I have seen them in later trucks, up to '80) and came in 5 lug ('71 and later 2wd) and 6 lug ('63-'70 2wd and all 4x4), as well as 2 different axle spline configurations ('63-mid '65 are 17 spline, later are 30 spline).
Bill Burmeister | | |
