5 members (Otto Skorzeny, 52Carl, Wally / Montana, Gray_Ghost, Mike B), 59 guests, and 1 robot.
Topics128,155
Posts1,056,868
Members48,456
#591812 11/12/2009 4:46 AM
yahoo
I am considering a 4 speed Saginaw tranny, mainly cuz my 3 in the tree freezes up going into 2nd( at least TRYING to go into 2nd) it wont go into gear. it's a 54 3100 panel truck with the 235-6. Is getting a Saginaw worth the expence, are they pretty dependable? sorry for the "rookie" question but that's what I am .Thank you. John Deurr
The gear splits are more pleasant, but you still have a direct final drive, so top speed does not change.
You'll either need to convert to open drive or buy the Patricks kit to convert the Sagninaw to torque tube.
John, I just finished mounting a Saginaw with Patrick's shift kit in my 49 suburban yesterday. If you want to see pics, have a look here and scroll all the way to the bottom.
http://gallery.mac.com/patrick.plummer#100287&bgcolor=black&view=grid
If you have power brakes, plan some mods to make the shifter fit depending on how you built your power brake booster unit (or bought). If you have the existing manual brake setup, you should be fine.
Welcome!
Thanks for sharing your installation. I had heard of problems with having to relocate the mastercylinder. Glad to know that only applies if you go with a powerbooster set up and stock is fine.
Hank
1951 restoration on website
http://www.hanklong.com
Thanks for all the help gentlemen, especially pplummer, I looked at your photos and was envious as to how someone can do a body off restoration like that,(I told you I was a rookie) I am fortunate enough to live 50 miles from Patricks so he did a rear end job on my 54 panel 3100.I'd like to find someone in the Phoenix area who is familiar with the chevy bodies to do some work for me. Thanks again, John.
I put a Saginaw 4 speed in my 51 1/2 PU mated with a 3.42 open drive rear. After some initial problems with the linkage hanging up it worked very well...with a '54 235 and dual carbs/headers it ran comfortably at 70+ on the highway. The linkage problems were the end problem caused by a bad engine mount and the consequent engine torqing/twisting. I moved the master cylinder to the drivers sideframe rail with no problems.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
John, I am envious that you live 50 miles from Patrick's! :-) However, i'd be broke if I lived that close. I'd always be rebuilding old stovebolts!
Sir Searchalot
Sir Searchalot
The Saginaw has annular grooves in the input shaft which tells the ratio. See below: Sorry can't figure out how to keep it from eliminating my spaces but you can figure it out. I see "create a list" but don't know how to use it.
1st 2nd 3rd 4th
no grooves 2.84 2.01 1.35 1.00
1 groove 2.54 1.80 1.44 1.00
2 grooves 3.11 2.20 1.47 1.00
3 grooves 3.50 2.47 1.65 1.00
