3 members (Nick in Manitou, TooMany2count, klhansen), 120 guests, and 4 robots.
Topics128,109
Posts1,056,240
Members48,437
#591716 11/11/2009 9:56 PM
I am in the process of documenting the bell housings we all talk about (http://s985.photobucket.com/albums/ae337/csparkhurst/Bell%20Housings%20Catalog/.)
I specifically need pictures of bell housing part numbers 3738373, 3742257, 3765710, 3836315, and 3836741.
I'll take anything I can find, but would prefer pictures of all six sides and the casting number. In or out of the vehicle.
Your help will be greatly appreciated.
3B Offline
Hy Chip1951, could you tell us what those part numbers were used in, in my experience part numbers and casting numbers are not very often the same, thanks.
3B #591920 11/12/2009 6:25 PM
The numbers I have obtained are based on early Corvette useage (the reference chart accompaning the catalog pictures.) It was the only reference material I was able to locate to date.
It is the casting number by which I am identifing parts.
Chip,
Are you saying that the 5 bell housing numbers you listed above are for the 53-55 Corvette, 235 engine.
Also, are they casting numbers or part numbers.
-Tom
1950 Chevy 3100 w/ 1956 235
Chip I went to the books last night and here is what I found:
Master Parts Catalog 1929-1953 6-cylinder models Section 0.683
Housing, Clutch and flywheel
40-48 All Pass Casting #839181 part #604361
48-53 All Comm/utility Casting #3835201 part #3847679
49-53 All Pass(ex PG) Castin #3688001 Part #3691993
Chev/GMC Truck Parts catalog #452 Chassis/Commercial Bodies
Section 0.683 Housing Assembly, clutch
41-47 All 3847361
48-53&54 1st 3847679
None of my books referenced the numbers you have listed above. If you continue to look the section number and definition of what they are called may help.
