1 members (3800GUY),
89
0
Mod | | | Forums66 Topics128,189 Posts1,057,336 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I know the standard answer is "it's your truck, do what you want" but I'd like to hear from some various points of view. I'm starting the restoration on a 57 1-ton and I'm undecided about what to use for a bed. It currently has duals and a flat bed but I'm considering changing to single rear wheels and building a stepside bed. I may do a little hauling but this truck will not be a work truck and it will not be a show truck. I've never seen a 9' stepside bed except for photos but I know a lot of people don't like the looks of long beds. I'd like to hear opinions both on appearance and drivability, such as getting around in traffic and handling, etc. Any thoughts and experience you're willing to share will be appreciated.
Jeff
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'm one who thinks 9' step beds are unattractive, and a dually with singles would make it more so, as well as not being any easier to get around or handle - with a 1 ton it's the length, springing and gearing that make it handle like a truck in traffic, rather than a car .... a dually pickup could be interesting, but a 1 ton flat deck look good, you can do some real nice detailing with stake sides
Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its your truck, do what you want.
I happen to like the 9-foot beds. I've thought about creating one with duals, but haven't done anything in that direction. I did see one done that way a few years ago at a car show. I'm sure I took pictures of it.
Regarding driveability, I don't think bed choice will make much difference, though the exact configuration the bed sides and the mirrors may make a difference.
Duals versus single-wheel does make some difference in rear width, but done the stock way its not a lot of difference and may not make any real difference.
Wheelbase and turning radius do make a difference. I'm not sure how long a Task Force 1-ton is, but at 137 inches the AD 1-ton is a long truck. I used to drive an extended-cab long-box 1-ton with a 155 inch wheelbase and that thing could be a challenge to park. Length and visibility are two factors I'd consider carefully.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2008 Posts: 131 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 131 | We debated the flat-bed / stake truck Vs. step side for my AD for a long time. We went back and forth, back and forth.  Eventually we selected the step side bed because we liked the look (Note: I have an AD). My truck started as a stake-truck and the bed was 10 feet, so going to a 9 foot made my truck shorter. Personally I like the step side (But I did not have dual wheels.) With dual wheels I think I would have made it a stake struck. Good Luck and let us know what you decide 1952 Chevy 3804My 1952 in the Gallery The only thing necessary for the triumph of evil is for good men to do nothing." - Edmund Burke | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Whats the point in dual rear wheels if you do not have a heavy load or are pulling something all the time? Just more rubber to buy and wear out.
Flat beds also tend to sling around more road debris. Full fenders keep the truck cleaner.
Keep in mind that the flat bed floor will be higher off the ground as well so if you do haul something heavy/bulky it will be more work to get the load up there.
Having said that, if you have a 5 pice band or a crowd on it in a parade the flat bed is really great.
Also with a flat bed you can place another alternate fuel tank under the bed or get the original tank out of the cab.
I have had both and my 41 1 ton has a bed and fenders that is the best way for me. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | They are both great! Sounds like you need another truck doesn't it?
Grigg | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If you don't run duals the cool 18 inch wheels end up looking funny.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Well, I might need 2 more trucks because I'm bouncing between 3 different ideas. I'll probably leave it as a flat bed for now since that's what I've got and it requires the least work and money. But I've got 2 short beds at my disposal so I can build a 9' step bed someday and switch to single wheels or I can build a wider step bed that clears the outside duals and put tubs in the inside like a fleetside bed to clear the inside wheels. I've got plenty of work to do in the meantime before I have to make a final decision. By the way, I was able to drive the truck down the road this weekend for the first time; about 5 miles. I took it to town to the car wash to clean it up a bit. It ran pretty good on the way there considering it hasn't been started in 5 years. On the way back it ran pretty rough because I washed the engine and the old plug wires have been chewed on by mice. I was pleasantly surprised at how easy it was to steer. We had an old '57 farm truck when I was a kid that was a bear to steer so I was expecting this one to be the same. At least I know that I won't have to spend any more time trying to figure out how to add power steering. Now I'm going to put the HEI distributor and new wires on it and drive it a little before I begin the cosmetic surgery. Hopefully it can come out of hybernation next spring ready to roll for another 50 years.
| | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | I really like the look of the 1 ton with the 135" inch wheelbase with duals. A nice 9-10' steel bed is easy to find. That's what Ive done to one of my 1 tons and plan to do to my second. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I haven't found those beds that easy to find... I'd love to find a nine-foot '54/'55 1st bed.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | It is your truck. But I like the 9' stepside. I have a art deco 47 with the step side and a 62 with a 12' flatbed. The 47's bed always gets more comments. It is older, but most of the comments are about how longggggggg those running boards are. Even on a Advanced Design or like your Task Force the step is longer than say a 1/2 ton.For work the stepside is easier to load than a flatbed. Good luck
1947 1Ton stepside 1962 K20 Fleetside 1962 C40 12' flatbed 1963 C10 Stepside 1963 C20 Fleetside 1965 C10 Stepside (Daily Driver) 1973 C20 Stepside fire truck 1973 C50 Utility truck Houston Power & Light
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I haven't found those beds that easy to find... I'd love to find a nine-foot '54/'55 1st bed. Click
Bruce | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | The '54-'55 1st 9' bed sold on ebay today.
Bruce | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I guess I need to find one less that 1200 miles away!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I found a 9' stepside bed recently. It's a '70 model but I think I can easily change the fenders to the older syle. Here's a link to a photo of the donor truck. http://i305.photobucket.com/albums/nn214/jfnar/57%20chevy%203800/70-1-ton-back.jpgI didn't buy all the fire equipment in the back but I got the aluminum trim around the sides. I plan to keep as much of that as I can. I also bought the 4.10 posi rear axle. Now I've got to find some 19.5 single wheels. By the way...welcome back tons o fun. I missed you.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Looks like a good find!
That bed mounted equipment may mean the bed has been protected and hasn't been beat up by loads.
I'd like to hear about the challenges involved in changing the fenders. I may try this approach some day too.
