| | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 25 | I am in the process of documenting the bell housings we all talk about ( http://s985.photobucket.com/albums/ae337/csparkhurst/Bell%20Housings%20Catalog/.) I specifically need pictures of bell housing part numbers 3738373, 3742257, 3765710, 3836315, and 3836741. I'll take anything I can find, but would prefer pictures of all six sides and the casting number. In or out of the vehicle. Your help will be greatly appreciated. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Chip1951, could you tell us what those part numbers were used in, in my experience part numbers and casting numbers are not very often the same, thanks. | | | | | Joined: Apr 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 25 | The numbers I have obtained are based on early Corvette useage (the reference chart accompaning the catalog pictures.) It was the only reference material I was able to locate to date. It is the casting number by which I am identifing parts. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Chip,
Are you saying that the 5 bell housing numbers you listed above are for the 53-55 Corvette, 235 engine.
Also, are they casting numbers or part numbers.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Chip I went to the books last night and here is what I found: Master Parts Catalog 1929-1953 6-cylinder models Section 0.683 Housing, Clutch and flywheel 40-48 All Pass Casting #839181 part #604361 48-53 All Comm/utility Casting #3835201 part #3847679 49-53 All Pass(ex PG) Castin #3688001 Part #3691993
Chev/GMC Truck Parts catalog #452 Chassis/Commercial Bodies Section 0.683 Housing Assembly, clutch 41-47 All 3847361 48-53&54 1st 3847679
None of my books referenced the numbers you have listed above. If you continue to look the section number and definition of what they are called may help. | | |
