3 members (Guitplayer, baldeagle, MickeyP), 104 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#591358 11/10/2009 8:59 PM
I got my alternator,brackets,and wire.I'm going to hook it up to my existing regulator at the(BAT.)terminal.The alt.is only 45 amps,I'm using a 10 gauge wire,and I have a 30 amp breaker. Should I still fuse in between the alt.and reg.in order to use my charge gauge?
If I put the breaker in will continously pop because it is only 30 amps?
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Riding in the Passing Lane
Don't use a fuse or a breaker. Put a short piece of fusable link in the circuit.
1972 Chevy c10 Cheyenne Super
Your profile says 53 2ton, that would have a generator. The regulator for a generator is different from the regulator for an alternator. If your alternator is a modern gm alternator it would have a voltage regulator internally. You would have to wire it differently.
Tommy
59 apache 1/2t
261 short stepside
PapaJ,
Tommy is right on! Even the old 10DN which uses a external regulator has no regulator terminal marked BATT. You must be using the term 'alternator' quite loosely. smile
Stuart
If I run the one wire(internally regulated)alternator to the bat. terminal from which I removed the generator wires I'll be able to use my dash amp gauge.Using this terminal as a tie in point to charge the battery.
1953 Chevy Two-Ton
Ex Hall Monitor
Ex Hall Monitor
I thought that's what you were referring to. That's the way I did my one wire installation.
PapaJ,
OH......I guess I didn't catch the drift of your question. As Tiny noted, that is the easiest way to tie into the existing system. IMHO, the alternator output itself isn't normally fused.
Stuart
