7 members (Shade Baby, Pete1946, frogfarmer, baldeagle, 1955 1 Series, Jon G, 1 invisible),
97
8
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 123 | I am just starting to learn about this truck and I am looking for a good shop manual so I can get acquainted with the inner working of these trucks. I have already found the owners manual. This manual says it is a supplement to the 1955 edition, so do I need both the 1955 and 1956? Anyways your suggestions are much appreciated. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The 1956 Supplement Shop Manual only has the new 1956 items not covered in the 1955 Manual. Since you have a 1956 truck, you need both. Mike B  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The '55 manual is also available here online for free.
Bill Burmeister | | | | | Joined: Nov 2009 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 123 | Thanks for clearing that up guys. That's what I thought. | | | | | Joined: Nov 2009 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 123 | Along these lines, is there a good parts catalog to look at? I found the 29-57 master parts catalog but it is pretty intimidating trying to use online. Is there something that is available in print? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The same catalog is often available, used, on eBay.
Once you get used it, the on-line catalog is far superior to thumbing through the hardcopy catalog. I have both (and I have a copy on CD-ROM) - my preference is still the on-line catalog.
Tim
