5 members (baldeagle, cmayna, dt235sd, 2 invisible), 93 guests, and 6 robots.
Topics128,016
Posts1,055,337
Members48,419
#59147 04/13/2006 3:03 AM
Hey guys, I'm considering buying a 261 engine with bellhousing and SM 420 transmission (as a package) from a fellow bolter. Neither one of us is sure if it would be a direct swap. The 261 is in a 59 2 ton truck. I'm hoping the entire package will bolt up in my 48 3/4 ton (I realize I will have to drill holes for the front 'engine' mount). I have not seen the 261 in person but have seen photo's. The crossmembers where the bellhousings mount and the way the bellhousings mount look different between the trucks. Is this swap possible or will it turn into a major headache. I am not a mechanic and this is my first restoration so any help/input would be appreciated. Thanks, Scott
#59148 04/13/2006 3:05 AM
Hey I already answered this in your other post. No need to post twice.
