7 members (Shade Baby, Pete1946, frogfarmer, baldeagle, 1955 1 Series, Jon G, 1 invisible),
97
8
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59139 04/12/2006 9:49 PM | Joined: Dec 2005 Posts: 35 Junior Member | | Junior Member Joined: Dec 2005 Posts: 35 | Ok so I am going to ask a silly question, on a 1958 to 1962 chevy 235 six , what type of oil filter system was used if any ? External or remote or none.Thanks for answereing a silly ouestion for me. Chris | | |
#59140 04/12/2006 10:27 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is the difference between external and remote?
All 1958-65 235s that had an accessory/optional oil filter had an external, remote, by-pass (non-full-flow) canister oil filter (by AC, Fram, or others). The engine could have been later adapted for a full-flow oil filter (external and/or remote)
This is not a silly question. It is possible, however, that a majority of light trucks sold between 58-62 (with 6-cylinder engines) did not have an oil filter installed when purchased. | | |
#59141 04/12/2006 11:37 PM | Joined: Dec 2005 Posts: 35 Junior Member | | Junior Member Joined: Dec 2005 Posts: 35 | Ok so I am not loosing my mind, because I can not find eather or, in other words you just drove it for a bit and changed the oil, interesting.I am kinda new to the six cyl engine game,I have a 51 chevy wagon that has a 58-62 235 six and i was realy looking all around for the filter or external canister and could not find one so I thought maybe some one just took it off or when they did the engine switch forgot to install it. Thanks for the info. Chris | | |
#59142 04/13/2006 4:28 AM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Oil filters were an option! Easy enough to set one up now though- There are probably plugs in the block where the lines go.
