0 members (),
110
7
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59123 04/12/2006 4:48 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I have seen this discussed here before. Some guys say they are almost as good as discs. Mainly, what I want to know is how much did you pay for them from praisdynobrake or any other source?? I am considering running these on the front of my 52 3600. I'm thinking I may want to upgrade the Hucks to Bendix before I do this...any advice? Anyone using these for Huck brakes? | | |
#59124 04/12/2006 6:05 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I switched my 1939 from Huck to Bendix many years ago and found it to be a great thing. The Bendix are much stronger than the Huck. Any lining will give way better brakes on th Bendix, you will be happy with it. | | |
#59125 04/14/2006 7:04 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I am. I got them from parisedynobrake. Made a big difference - I am very pleased with them. My truck stops well. Another thing that helped was replacing my worn out of spec front drums which I got from autozone. I can't remember what they cost, but they were expensive, however, compared to a disc set up, way cheap. And I didn't loose my 1 ton rating either. | | |
