7 members (52Carl, Goach2, Hotrod Lincoln, Oswald, Hugh63c10, TUTS 59, cmayna), 140 guests, and 4 robots.
Topics128,204
Posts1,057,294
Members48,467
I have seen this discussed here before.
Some guys say they are almost as good as discs.
Mainly, what I want to know is how much did you pay for them from praisdynobrake or any other source??
I am considering running these on the front of
my 52 3600.
I'm thinking I may want to upgrade the Hucks to Bendix before I do this...any advice?
Anyone using these for Huck brakes?
Steve
'49 3800
'52 3600
'57 3100
I switched my 1939 from Huck to Bendix many years ago and found it to be a great thing. The Bendix are much stronger than the Huck. Any lining will give way better brakes on th Bendix, you will be happy with it.
I am. I got them from parisedynobrake. Made a big difference - I am very pleased with them. My truck stops well. Another thing that helped was replacing my worn out of spec front drums which I got from autozone. I can't remember what they cost, but they were expensive, however, compared to a disc set up, way cheap. And I didn't loose my 1 ton rating either.
