2 members (Hotrod Lincoln, Tronman), 167 guests, and 3 robots.
Topics128,257
Posts1,058,017
Members48,479
#591110 11/09/2009 10:53 PM
1 Offline
I am restoring a 1953 1/2 ton 3100 pickup. Does anyone know what color the interior should be from the factory? Did the firewall come black from the factory or was it painted the same color as the exterior? I also wanted to paint the running boards black but not sure if that was factory as well. Thanks.
1953 3100 Chevy 5 window
1971 Chevelle SS
Running boards were black.
The interior firewall was painted the interior color.
Someone else will respond with interior color information.
http://www.1954advance-design.com/D...pont/slides/orig_041953DupontB25S5E.html
Tim
1953Chevy:
I have the same model truck. This year was an exclusive color from previous and later years. A slightly metallic charcoal color was used. Jim Carter Truck Parts sells the correct blend in small quantities. Hope this helps.
DanB
Dan B. #591777 11/12/2009 2:18 AM
The color codes might be:
Ditzler (PPG)31104 (original code)
DUPONT 202-81407
PPG 27467 is supposedly the modern code (offset-code)
Some 1953 cab interiors might have been painted with the earlier interior colors.
Apprentice
Apprentice
I am doing a 53 GMC 1 Ton. The interior color question plagues me as well. Any idea what I would use? Is the GMC subject to the same variation as the Chevrolet? I bought Carter's paint and do not like the color at all
