| | | Forums66 Topics128,257 Posts1,058,017 Members48,479 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | I am restoring a 1953 1/2 ton 3100 pickup. Does anyone know what color the interior should be from the factory? Did the firewall come black from the factory or was it painted the same color as the exterior? I also wanted to paint the running boards black but not sure if that was factory as well. Thanks.
1953 3100 Chevy 5 window 1971 Chevelle SS
| | | | | Joined: Mar 2009 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 71 | 1953Chevy:
I have the same model truck. This year was an exclusive color from previous and later years. A slightly metallic charcoal color was used. Jim Carter Truck Parts sells the correct blend in small quantities. Hope this helps.
DanB | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The color codes might be:
Ditzler (PPG)31104 (original code) DUPONT 202-81407
PPG 27467 is supposedly the modern code (offset-code)
Some 1953 cab interiors might have been painted with the earlier interior colors.
| | | | | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | I am doing a 53 GMC 1 Ton. The interior color question plagues me as well. Any idea what I would use? Is the GMC subject to the same variation as the Chevrolet? I bought Carter's paint and do not like the color at all | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
