5 members (Otto Skorzeny, DadsFirstPickup, Charles in CA, Millenimech, J Lucas), 99 guests, and 1 robot.
Topics128,147
Posts1,056,798
Members48,454
#590808 11/08/2009 7:44 PM
HI, I have a roof/front window leak. the leak is on the drivers side and I poked at it and made a big hole in the inside of the cab above the window. I checked the outside oppsite the insie leak and found a couple of small pin holes in the underside of the roof overhang. can this be fixed? What do I need to do?
644x4
these trucks have a not so good design with the rain gutter around the roof.the water gets trapped and leaks under the seam.the guter needs to be cleaned and new seam sealer put in. my 62 has the same problem...our only option is pieces from doner cabs and fabbed pieces.as you can see from my pic i removed the roofcap and will be attacking the problem from both sides..heaven help me![IMG]http://i48.photobucket.com/albums/f216/applebag/Newpics029.jpg[/IMG]
