2 members (TexasA&M48Truck, Wayne67vert), 77 guests, and 3 robots.
Topics128,212
Posts1,057,463
Members48,471
Junior Member
Junior Member
i also have a 85 s10 that i was going to put a v8 in but i had to sell it so now i'm wondering if the 90 model straight 6 will fit i was looking at a 70 model nova at the bone yard and noticed the big 6 cylinder was almost on the ground with the motor mount setup.maybe i'll try it but if anybody s seen this done or done this,the 90 model 6 only has 69000 miles on it ,i got it from my grandpa he only used it on the farm.to feed with until he let my cuz drive it and he totaled the truck.boy was he lucky.
straight 6 in 90?
you sure it's not a V-6 4.3l?
either way you're gonna have to change some stuff.
(like the firwall if it's a straight 6)
the 4.3 won't be a bolt-in as the trans has to be changed cuz of the bellhousing. the mounts won't be the same but a wrecking yard should be able to cough them up..
i miss obscene phone calls...
Junior Member
Junior Member
my bad it's alate 1980's model straight 6 with californa heads
