| | | Forums66 Topics128,157 Posts1,056,878 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | My 1946 2 1/2 ton truck has been sitting here for a couple years now, so I am planning to finally get some work done on it this winter. The first thing I need to do is a COMPLETE re-wire. It's still OEM and no telling how good of shape it's in. I also want to convert to 12 volt. Anyone have a diagram or drawings handy so I can make my own harness? | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | There is a write up in the Tech Tips section on how to convert to 12 volt | | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | http://www.rebel-wire.com/These people are advertised in another section and there is a discount for Stovebolt members.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | With the cost of bulk wire and wire connectors these days the pre-made wire harness is about as cheap as making your own. | | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | I've actually got access to wire/terminals, etc. All I need is the "map"..... | | | | | Joined: Apr 2002 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 23 | I'm a little late to the game, here, but you can get a reprinted copy of the shop manual that will help (if you don't have this figured out already).
A great lady, a stovebolt, & a small town! What else is there? Aspiring '54 6400 dump truck owner 'Bolt On --------
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Try going here: http://chevy.oldcarmanualproject.com/There is a 1947 wiring harness shown. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
