| | | Forums66 Topics128,209 Posts1,057,462 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 24 Junior Member | | Junior Member Joined: Jan 2002 Posts: 24 | i also have a 85 s10 that i was going to put a v8 in but i had to sell it so now i'm wondering if the 90 model straight 6 will fit i was looking at a 70 model nova at the bone yard and noticed the big 6 cylinder was almost on the ground with the motor mount setup.maybe i'll try it but if anybody s seen this done or done this,the 90 model 6 only has 69000 miles on it ,i got it from my grandpa he only used it on the farm.to feed with until he let my cuz drive it and he totaled the truck.boy was he lucky. | | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | straight 6 in 90? you sure it's not a V-6 4.3l? either way you're gonna have to change some stuff.
(like the firwall if it's a straight 6)
the 4.3 won't be a bolt-in as the trans has to be changed cuz of the bellhousing. the mounts won't be the same but a wrecking yard should be able to cough them up..
i miss obscene phone calls...
| | | | | Joined: Jan 2002 Posts: 24 Junior Member | | Junior Member Joined: Jan 2002 Posts: 24 | my bad it's alate 1980's model straight 6 with californa heads | | |
