0 members (),
139
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | I have a 51 Chevy 3100 with the original 216 Babbet Banger and 3 on the tree. I am preparing to replace the clutch assembly (clutch kit). The parts store computer shows 2 sizes of Disk/Pressure plate assemblies a 9" and a 11". I am pre-ordering before disassembly and I do not know what size my truck currently has installed? Are the 9 and 11" assemblies interchangable with no problem bolting up to the standard stock 216 flywheel?
Best Regards Will
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If its a pickup, all it needs is a 9" clutch and that's probably what's in it now. GMC uses a different flywheel for a larger clutch. Chev probably does too. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | When replaceing a clutch you need to pull it first. There are many options. The 9 & 11 will not interchange on the same flywheel. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Yes a 1951 Chevy 3100 is a pickup....... Thanks for the 9" vs 11" vs flywheel application information.
Best Regards Will
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you pull the flywheel cover you can tell a 11" from a 9". The 11" pressure plate comes to the outer edge of the flywheel, the 9" is in about 1".
See the USA in your vintage Chevrolet! My Blog | | |
