3 members (1955firstseries, Roy Rodgers, elhippie64), 75 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#5901 12/02/2001 4:44 PM
I have finally installed the 302 GMC in my 48 5 window. I used an S10 T5 and 3:55 9 inch. I am now looking at radiators. Been thinking of a cross flow aluminum or something like that. The original radiator is beyond repair, even saving the tanks as per the radiator repair shop. If not this route, has any one used a radiator from salvage yard that fits with minimum fabracating?
L. Day
#5902 12/03/2001 12:16 AM
I'd really hate to hear about that nice, powerful 302 blowing a head gasket due to a shoddy junkyard radiator that gave up the ghost 2 miles from the next interstate exit.
I'd choose a QUALITY aftermarket radiator. 3 or 4-core. No less. Even if it costs $300+. I replaced my stock "hotwheels" radiator in my '66 stepside after running it for a year, constantly bringing the temp gauge up over the halfway. Now the temp gauge STRUGGLES to make it 1/4 way eek grin
-ftyler
#5903 12/03/2001 5:02 AM
Problem with newer rads is width. Most old trucks with vertical rads are narrower and no place to put new type unless you "hack-away" at metal. You can get new rads for these old trucks, just get the one for the 2-ton. It has more core and still fits in same space. Check vendors for these.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#5904 12/21/2001 6:41 PM
L.Day,
I second G.L.'s recommendation! It'll be worth the $$!
Especially with a 302 GMC to take care of!
It's a shame to look under the hood of an old vehicle and see some junkyard radiator butchered in.
It's kind of like getting a shot; it hurts for a little while, but you're better off in the long run!
Frank
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
