| | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 16 Member | | Member Joined: Aug 2001 Posts: 16 | I have finally installed the 302 GMC in my 48 5 window. I used an S10 T5 and 3:55 9 inch. I am now looking at radiators. Been thinking of a cross flow aluminum or something like that. The original radiator is beyond repair, even saving the tanks as per the radiator repair shop. If not this route, has any one used a radiator from salvage yard that fits with minimum fabracating?
L. Day
#5902 12/03/2001 12:16 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | I'd really hate to hear about that nice, powerful 302 blowing a head gasket due to a shoddy junkyard radiator that gave up the ghost 2 miles from the next interstate exit. I'd choose a QUALITY aftermarket radiator. 3 or 4-core. No less. Even if it costs $300+. I replaced my stock "hotwheels" radiator in my '66 stepside after running it for a year, constantly bringing the temp gauge up over the halfway. Now the temp gauge STRUGGLES to make it 1/4 way  -ftyler | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Problem with newer rads is width. Most old trucks with vertical rads are narrower and no place to put new type unless you "hack-away" at metal. You can get new rads for these old trucks, just get the one for the 2-ton. It has more core and still fits in same space. Check vendors for these.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | L.Day,
I second G.L.'s recommendation! It'll be worth the $$!
Especially with a 302 GMC to take care of!
It's a shame to look under the hood of an old vehicle and see some junkyard radiator butchered in.
It's kind of like getting a shot; it hurts for a little while, but you're better off in the long run!
Frank
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
