2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
Apprentice
Apprentice
Like the title says, the cross member near the middle part of the frame was rusted out pretty bad, this is the crossmember that sits right behind the cab, what im wondering is if anyone has replaced this before, Bolted in another one, i seen a post where they said grade 8 bolts should work fine but I kinda want to put my tig welder to use here, I dont want to box the frame and run custom crossmembers though, your thoughts on what a good way would be to go, and if anyone has a stock one for sale, thanks again stovebolters!!!!
I would go with the grade 8 bolts unless you are doing a showroom restore. If you are worried about them coming loose you could tack weld the nuts after tightening, but split washers should do the trick.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
