| | | Forums66 Topics128,037 Posts1,055,580 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 76 'Bolter | | 'Bolter Joined: May 2004 Posts: 76 | Let me get yall's thoughts on this. My 54 (6V +grnd) does not turn over. I have had the starter rebuilt thinking it was totally dead and installed a new and fully charged battery. The lights and horn work, but when I step on the starter the ammeter drops to 0. Any Ideas? | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I've had the starter drive gear stay engaged in the flywheel and it acts like a dead starter. My solution was to put the truck in gear with the clutch released, then rock the truck forward and back. This turns the engine and flywheel, which releases the starter drive gear. Hope this helps. | | | | | Joined: May 2004 Posts: 76 'Bolter | | 'Bolter Joined: May 2004 Posts: 76 | I'll give it a try and see what happens. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sounds like who ever rebuilt your starter has one of the field coil leads shorted internally. Best take the starter out and get it up on the bench. Using jumper cables and your new battery see if the starter is operating correctly there before installing it in the truck. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Can you turn the engine by hand? When was the last time it ran?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
