8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 8 New Guy | | New Guy Joined: Nov 2009 Posts: 8 | I have rear cab mounts that are not the round hockey puck style, has anyone ever seen this type?
Thanks | | | | | Joined: Sep 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 66 | Do they look something like this ? | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I have rear cab mounts that are not the round hockey puck style, has anyone ever seen this type?
Thanks those are the standard 3/4t or 20 series rear cab mounts, obsolete. one can install the 10 series rear cab mounts but you have to install the c10 series frame brkts for that application ron | | | | | Joined: Nov 2009 Posts: 8 New Guy | | New Guy Joined: Nov 2009 Posts: 8 | | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | If you need the original style re-worked, then Steele Rubber does it for about $118/pair using original cores.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
