0 members (), 126 guests, and 3 robots.
Topics128,101
Posts1,056,181
Members48,436
#589498 11/04/2009 1:39 AM
does anyone know what the original brand of hubs on 1961 chevy k15 and
Where can you buy seals and bearings for 1961 k15 transfer case? thanks
my61k10 #589527 11/04/2009 2:42 AM
What kind of transfer case do you have in it now? It came with a rockwell t-221 and if thats what you have a company called novac has what you need for it.
my61k10 #589531 11/04/2009 2:43 AM
What kind of transfer case do you have in it now? It came with a rockwell t-221 and if thats what you have a company called novac has what you need for it. If you need hubs check out milemarker.com
joek3167 #589580 11/04/2009 3:59 AM
k10 Offline
http://cgi.ebay.com/ebaymotors/GM-T...ck_Parts_Accessories?hash=item5ad25f5ec7
For the Timken T-221
The hubs are NOT Warn. They are GM. They are not reproduced. It would very acceptable to put on a pair of Warn hubs. They will probably work better than the originals anyway. I found an NOS one to replace the right side. That was on EBay many years ago. You might get lucky, you might not. Most stuff becomes available, it just depends on how much and how long you'll wait.
Also, a bit of clarification on "k" numbers. If you have a 61 K15, that is a 4x4 (K) longbed (15). A shortbed would be a K14. If you are doing searches for parts, You would refer to your truck as a K10, not a K15. No one lists anything for a K15. Obviously a K20 is a 3/4 ton truck. The K10 hubs are different from K20 hubs not only for the bolt count 6 vs 8), but are a completely different design.
Something like this may work for you, but don't take my word for it-do your homework. The stock front axle on a 61 K10 is a Dana 44. (44.5F)
http://cgi.ebay.com/ebaymotors/NEW-...ck_Parts_Accessories?hash=item27ac9258df
k10 #589650 11/04/2009 12:51 PM
I have a question, if k-14 is a short and k-15 is a long and c-10 is a 2wd is there a different id # actuallity between 2wd short and long beds? i.e. a short bed being a c-9?
i have a 61 gmc k1001 1/2 ton short bed step side and it had very old warn brass lock outs, and at the time (1989) all i could find were dualmatic lock outs from mile marker florida.at that time $180.82 #11001-01
old dog #589750 11/04/2009 8:31 PM
k10 Offline
Those would be C14's and C15's. No C-9's. smile
The front of the service manual has all of that stuff. So does a restoration pack from chevrolet. Although if you don't already have one, the word is, that they now charge a fee for a new restoration pack.
Just an FYI, the lockouts are actually an option. You could order a 4x4 without the lockouts so that the front axle is always locked. Kind of like a modern 4x4. I don't know about the parts for that setup.
