8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | Anyone have a suggestion for a 6 cyl. tach for a 292 with HEI ignition? I would like one that I can mount on the column. Thanks! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Auto Meter, Sun, and Stewart-Warner all have exellent tachs that will work just fine with your enngine. If you have a tach terminal on the distributor, that makes wiring even easier. I've seen on the newer styles where you don't even have to clip any wires to make them work with engines other than an 8 cylinder. They're using micro-switches now.
Bill Burmeister | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Can't help you with fabricating a case or flat mounting on a '66, but I used a tach from a Chevy Cavalier Z24 with V6. I have a 292 with HEI. Fortunately the '67-'72 already has a location for a tach and it wasn't to difficult to modify. Aftermarket is probably your best bet for a '66.
The Cavalier also had a great small diameter, FAT rim steering wheel. With power steering I don't need that wagon wheel size that was original. The original GMC horn button fit the Cavalier wheel with only a small knife trim on a tab.
'67 GMC 3/4 292 4spd
| | | | | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | I have that exact set up on my '64 C20. Most current tach's out there have a setting for either 4,6 or 8 cylinders. You may have to take the back of the housing off to find where you make that adjustment. It is easy to hook up on the HEI because there is a connecter already there marked "tach". It is there with the rest of the wires plug into the cap. You just have to connect the signal wire (the one that would normally go to the coil) to the connector. It works slick. Good luck! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I just had Custom gauges and a tach made by SpeedHut.com. for my 57' BelAir. They can make you a 6 cylinder 4000 RPM tach if you want. Everything is now 8K and I only wanted a 6K tach and they did it for me. Custom lighting, colors, faces, mounting options and memory too.
It was not as expensive as you probably are thinking. My tach, oil, temp and pressure gauges were about $450 which com[pares favorably with AutoGauge and others. | | |
