0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 41 New Guy | | New Guy Joined: May 2009 Posts: 41 | has anyone used studs on their main caps? The lack of dowels or anything to index the caps worries me, but finding the right size studs seems to be difficult. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Bolts on main caps has worked for over 70 years. Why change? | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i put my 235 together after the machining and i will agree it seems a little crude after working on more modern engines but the cap bolts do fine and i think the caps move around a bit and get like they want to be. i dont think it is a good idea to over turn these motors. philip | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | If You change to studs You are going to change the torque settings so it would not be the best thing to do and the cap would not index any better just dropping onto studs than installing it with bolts as long as the fit is good ( factory) between the bolt and the cap .
Pete | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | When I built mine, I asked the machine shop owner, who has been dealing with these engines forever it seems, about converting to studs. he told me it wasn't necessary, and that bolts do the job just fine. Plus, after doing some checking with a few stud sources, including ARP, no one makes the correct size studs for use with the Chevy 6 anyway.
Bill Burmeister | | |
