| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 8 New Guy | | New Guy Joined: Oct 2008 Posts: 8 | Hey team. This is for anyone who has done the disc brake conversion on their AD. The instructions are pretty easy to follow, but has anyone read that you have to leave off the stop bracket on the straight axle. It originally stops the spindle from hitting the I-beam when turning to back up. But the way my configuration seems to be is that the bolt on caliber bracket takes away a LOT of the turning ability when backing if you leave the stop brackets on. Or am I suppose to grind off some of the bracket to give make space for the stop bracket to work properly? Thanks in advance | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I ground a notch in the caliper bracket to clear the stop. I would not recommend removing the stop. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Same here, just made a small notch for the stop bolt to clear the bracket. | | |
