| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | My '96 chevy,6.5 diesel is acting up.Everything is pointing to the PMD unit on the injector pump.My question is,can i change this part myself,or should i let the"professional"do it.I'm told the pump timing would have to be reset.I can change parts,but,when it comes to the fine tuning,i go elsewhere.Thoughts please. Thanks in advance Roy  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | You can change the controller with out pulling the pump, its a little more work but it can be done. Even if you pull the pump, the timing marks are on the pump housing and pump itself, just line them back up. Look at the 12:00 o-clock position on the pump mounting face for a small line stamped across both pieces. Also, if you pull the pump, you have to pull all the lines off, don't bend them out of the way!
Check on some of the diesel site on the web for information on relocating the controller. Heat is what breaks them down. We have mounted some in a heavy heat sink out on the valve cover with good results. The new issue of GM controllers is different then what was issued on the truck, and we have had good luck with these as well.
Joe | | |
