| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 98 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 98 | Buying a 1949 GMC 2 ton COE project and have questions about the sheet metal on it. Truck is still out of state so I cant measure it myself. What guage steel as used on the fenders and cab? To make rust patches do I use cold rolled, mild or what. Will work the best? I will buy patches when possible. Who make the best quality? Thanks, John
| | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Most of the sheet metal in the cab and the fenders is 19 gauge. The floor is heavier. Most of the patch panels come from the same source. The source is a company that also makes the entire cab. Some of the older ones are from a different source and the older ones that I have seen are painted in grey primer. | | |
