8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | So, I was looking at getting a th700r4 at the junkyard, I saw an 88 in a chevy 1/2ton and I came up with 2 questions: I liked the 88 because I have read often that 87 and up are better. ~ The trans does not have a speedo cable... Yet, an 88 should be a th700r4, not an electronic 4l60e (those only started in 93), so, what is up with that? How would I connect my speedo? ~ How do you remove the TV cable from the trans? I have removed the little screw that holds the cable on the trans case, but the wire is still attached inside the trans!... So? And how do you remove the TV cable from the throttle bracket? The throttle cable has a little clip, easy to remove, but the TV cable has no clip... Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | 88 and newer are all electric speedo on GM's
you need to either get a converter box for $300, or go electronic on the gauges.
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Isn't it easier to just change the tailshaft housing to an older model with cable hook up?
| | | | | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 | you can just change the tailshaft housing and have mechanical speedo. the tailshaft itself has the hole for the clip that holds the plastic gear on
50 chevy 3100
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | The TV cable housing at the throttle body has a plastic lock that can be squeezed with a pair of Channellock pliers. Then it will push through the bracket, but you'd better grab the bracket, too. The cable end itself just pushes forward off the stud on the throttle linkage. It's plastic, so don't break it! Even if you have to modify the way the bracket bolts on, you'll need it to complete your installation. On the transmission end, once the top of the cable housing is free, you can pull the housing up far enough to unclip the cable. There's a short wire that connects the TV valve on the valve body to the cable, and it goes about an inch up into the cable housing. Depending on the year model, there might also be a vacuum switch mounted on the firewall that is needed to get the converter clutch to lock up. Jerry
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Thanks for the tips, I have bought a tailshaft housing from an older trans, that will be easier, with a bit of luck, I will be able to keep my current speedo cable! Your info also helped me look at the TV cable better, now I see all there is to see. It is funny how sometimes, we can get stuck with simplest thing, really! (like how the cable is attached to the throttle bracket, duh!).
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Besides the vacuum switch, there is an extra brake pedal switch to unlock the converter.
