0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58885 04/08/2006 11:58 AM | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | I have a 235 in my 1941 1/2 ton. I do not have trouble in starting but when I drive any distance, cut the engine off and try to restart it is very difficult to restart. Sometimes I have to use the carb. starting fluid to get it to go. I have replaced the alternator, regulator, starter, battery, plugs, plug wires, carburator, fuel pump, thermostat, added a heaver battery cable, new points and rotor, added fenton headers and have flowmaster dual exhaust. It seems like everything is there. I'm baffled.
Greater love have no man than this, That he let his wife drive his truck to the grocery store. ........
#58886 04/08/2006 12:48 PM | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | 8thairforce,It does sound like you are getting vapor lock.Make sure your fuel lines are away from the exhaust manifold and heat.It is best to run the lines as close to where the factory ran them as possible.You could also try to insulate the lines with cloth heat wrap like is used on aircraft engines.We used to call it fire hose.Let us know how you make out.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#58887 04/08/2006 1:29 PM | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | One thought. Does the carburator need a heat shield gasket?
#58888 04/08/2006 4:46 PM | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Don't worry about anything else. This is a fuel problem, not a spark or temperature problem, from your description. With all the threads on clogs from old tanks, I would look into the fuel supply part of the system. Start at the tank and work your way toward the carb. Maybe you get enough flow to idle but not enough flow for driving?? | | |
#58889 04/08/2006 10:24 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Normally vapor lock shows itself as the engine acting like it's running out of gas while driving causing the engine to stall. Next time you shut it off hot, pull the air cleaner and work the throttle. If your accelerator pump is squirting gas it's probably not vapor lock.
#58890 04/09/2006 12:42 AM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#58891 04/09/2006 1:35 PM | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | Thanks Folks. I'll try all the suggestions.
