1 members (51sub),
128
Mod | | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 10 Apprentice | | Apprentice Joined: Nov 2008 Posts: 10 | I have a 1966 C-20 with a 250 and granny four-speed with 4.56/1 rear axle. Truck was GREAT when I pulled trailers not much of that going on now so truck is not getting used. I have found a 1980's ford 4x4 frame with complete driveline still attached pretty cheap and I already have a 1964 C-60 Front cap that would virtually eliminate my biggest rust issues. Am planning on swapping the frame, driveline, and front cap also am going to put in a bench seat out of a dodge for comfort and swap out the gauge cluster for a walnut/Stewart warner inlay. Am just looking for any information on how to make this swap as smooth(yeah right) as possible. One other thing as soon as I can It will be getting an inline back in it(300 six hopefully) but I want to make that blue oval small block bite the dust first(what fun)
Thanks for any help "Junkyard" Brown
Parts may come and parts may go but a good truck always stays the same
| | | | | Joined: Feb 2004 Posts: 29,809 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,809 | What engine does the Furd have now? I'm in the market for 351's, either Windsor or Cleveland models. My farm is straight south of Nashville about 60 miles, and I'm willing to travel to pick up an engine. (Mid-Iowa a couple of weeks ago!) Jerry
| | | | | Joined: Nov 2008 Posts: 10 Apprentice | | Apprentice Joined: Nov 2008 Posts: 10 | The motor on the frame now is what the previous owner says is a 302. I will check it next time and make sure. What year models are you looking for, what shape do you want them in and how much are you wanting to spend The nickname "junkyard" was given to me by coworkers due to my obsession with junk, so just let me know what you need. One other qustion for the 'bolt, how hard is it going to be to fit a '68 steering column in the '66 cab?
Thanks again "Junkyard"
| | | | | Joined: Feb 2004 Posts: 29,809 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,809 | I build 302 and 351W engines for round track racing, and the Cleveland engines fit a Pantera I work with occasionally. Anything other than a trashed-out junker would be worth considering. Jerry
| | | | | Joined: Nov 2008 Posts: 10 Apprentice | | Apprentice Joined: Nov 2008 Posts: 10 | I will look and see what I can find for you. can anyone tell me what cabs and front caps would fit back on my '66 3/4t frame(direct fit or as close as possible) as I will be keeping it and the driveline intact to maybe build another truck one day.
Thanks "Junkyard"
