0 members (),
230
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 52 | I AM CONSIDERING DOING SOME KIND OF ENGINE WORK ON MY 65 AND WAS WONDERING IF ANYONE HAS USED ANY POWER ADDERS LIKE TURBO OR BLOWERS?IF SO COULD YOU LET ME KNOW WHAT YOU PUT IN AND HOW IT WORKS FOR YOU? | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I haven't done any of this yet but if you have time to visit this site http://www.inliners.org/ check out their bulliten board. They have a lot of info about this kind of stuff.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | http://www.spaturbousa.com/home/This company has a turbo exhaust manifold for the 250ci and distributors all over North America. Inliners requires you to pay to be a member, but do a search for turbo 250ci here and you should find a link directly to the Inliners Blower motor page.
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't think you have to be a member to access Inliner's bulletin board. Give it a try. http://www.inliners.org/ubbthreads/ubbthreads.php/ubb/cfrmOf course we welcome new members. There is a lot of knowledge to be shared by the group. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Contact Hank at inliners (Mean-buzzin-half-dozen). I think he forgot more about hopping up the 194/230/250/292 than most people ever knew.
| | | | | Joined: Oct 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 37 | my 67 has a 250 six cylinder and I would not mind to do maybe a cam swap or work on the head a little for some extra power myself !!
1967 C10 shortbed fleetside 1/2 ton painted bumper's & hubcap's no option's driven year round but truck won't start when it's raining or snowing ? 1967 camaro RS 327 all stock DON'T WORRY FOLK'S THIS BIG WHEEL THING IS LIKE A KIDNEY STONE IT WILL PASS ! O-RING'S WERE NEVER MENT TO BE USED AS TIRE'S ! 1967 c10 2wd swb 250 3spd | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | A mechanical blower or turbo can certainly produce a lot of power, but the biggest gain for the money is mild boost with a nearly stock engine, otherwise it's another money pit. Read my article: http://victorylibrary.com/mopar/blower.htmConventional speed equipment (big cam, ported head, 4 bbl., header) is a nice project/hobby, but not cost-effective in terms of power per dollar, or maximum power. You still have a small engine when you're done. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | For the cost of adding any kind of boost, either turbo or mechanical supercharging, you can do a lot of more conventional go-fast modifications. You'll need to do an engine rebuild in the process, however. The 250 has dish-top pistons that serve to lower the compression ratio to emission-controlled levels. By substituting flat-topped 307 V-8 pistons, which are a direct replacement, you'll get a compression boost. I've built 250's with pretty radical cylinder head milling, .050" in one instance, without piston-to-valve interference problems, but I was using a stock cam in that one. If you can get away with a fairly radical grind cam AND high compression, that's the best of all possible worlds, because the compression bump compensates for the reduced cylinder volume created by the longer duration cam on the compression stroke. In most cases, the effective cylinder pressure isn't much more than stock, even with high-compression modifications. Using a radical cam WITHOUT increasing compression is a huge mistake! Improve the intake and exhaust with appropriate manifolds, and add a high-performance ignition system. You'll spend about as much as adding a turbo or a blower, but the power increase will be a lot more noticeable. Jerry
