| | | Forums66 Topics128,050 Posts1,055,753 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58823 04/05/2006 9:20 PM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Is there an easy way to know roughly what duration cam I got in my engine? Stock, mild or hot? I never had another engine and can't compare with another known stock or modified engine.
I have a 1962 235 with a 1955 9-1/4 flywheel (original trans) with BB, 5 and triangle marks. It seems the triangle indicates max. possible advance at 32-34* If I time the engine at the recommended 5* mark per shop manual, it never comes close to pinging and the exhaust is rapping like crazy at deceleration - as in too retarded. It seems to run much better, if I time it around the triangle. Then I get slight pinging at WOT uphill and hardly any rapping in the exhaust when decelerating. The engine is smoother, quieter and responds better when accelerating.
Could it be that I have a non-stock cam with higher duration that likes more max. advanced timing? It does feel a little bumpy and uneven at 500 rpm idle and smoothes out only after 800-1000 rpm. Also I noticed at 2500-3000 rpm the engine is smoother and quieter and runs very nice without overheating.
It doesn't sound or feel like it, but I am worried that I am running too advanced and may damage the pistons. | | |
#58824 04/05/2006 9:52 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Set it where it pings & then retard it just enough to stop the pinging. That is the best setting & will not damage pistons. It,s doubtful you have a modified cam in it. They are pretty rare in those engines. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#58825 04/06/2006 12:37 AM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | You are right - that's what seems to be the best setting. Been running it that way for many years, every day. I checked TDC on cyl#1 and the pointer is perfectly above the BB on the flywheel. I also have the correct distributor and vacuum adv. for the year.
I just never knew why this engine prefers base timing at idle to be set so far advanced at the triangle mark, which I understand is the total advance recommended for these engines after max. centrifugal advance. However I'm already there at idle...
I often wondered about the cam. This engine was rebuilt at some point. It has a 55 head and the crank is also not original as it only accepts the smaller 55 flywheel. But I also can't imagine anything but a stock cam. | | |
#58826 04/07/2006 7:24 PM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Just a quick note:
Learned that the triangle is actually used to check cam timing.
Also found other bolters in past threads, who had best results using it as the timing mark, rather than the BB. | | |
#58827 04/08/2006 5:32 AM | Joined: Nov 2004 Posts: 2,402 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,402 | I'm no expert, but I doubt that you can identify which cam you would have without taking it out and taking some accurate measurements. Unless there are some numbers stamped on it. That would also require removal, unless its stamped on the end.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | |
#58828 04/09/2006 12:30 AM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | You can check total cam lift with the cam in the engine using a dial indicator .You could then compare to specs of a stock cam.This would at least give you a starting point.You may have to do some research to find the stock specs?
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
