| | | Forums66 Topics128,013 Posts1,055,322 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 5 New Guy | | New Guy Joined: Sep 2009 Posts: 5 | What do you all use for a headliner on the burbs and panels? I need something flexable enough for the curves on the sides. Any photos would be great. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is a photo album with comments of Jim Carter headliner installed on a 1954 Suburban. Not all the pieces were cut properly. I would do one thing differently: varnish/seal the back (upper) side of the cardboard. The pieces bent into place fairly easily - two people working together made the job easier. Here are a few photos of roof insulation that was installed prior to installing the headliner. Tim | | | | | Joined: Sep 2009 Posts: 5 New Guy | | New Guy Joined: Sep 2009 Posts: 5 | Thanks for the input. What would a fella use on a low budget. I saw 1/8 inch paneling at lowes. Could that be used and could you apply fabric to it? Sorry for too many questions in one sentence.My build is for a 66 panel. Thanks again. | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | you can get frp panels, 4 x 8 fiberglass about 1/16 thk at lowes or h.d. one side textured one side smooth. | | | | | Joined: Sep 2009 Posts: 5 New Guy | | New Guy Joined: Sep 2009 Posts: 5 | Thanks DThela, I use this at work at least once a month. Every time I install it I think, headliner? | | |
